Dragon Tools. Editor de DSK y VDK
Agradecido : 2074 veces
Agradecimiento recibido: 1786 veces
Mensajepor ron » 14 Feb 2016 12:56
DragonDos [Rolf Michelsen]
Es una utilidad de línea de comandos para manipular sistemas de archivos DragonDos almacenados en un disco virtual. Tanto los formatos de disquete virtual de DSK y VDK son compatibles. El programa puede crear sistemas de ficheros DragonDos vacíos, listar archivos, borrar archivos y copiar archivos entre el disco virtual y el sistema de archivos local.
http://www.rolfmichelsen.com/dragontools/
Dragon Tools is a collection of tools for interfacing with the Dragon family of 1980s home computers in a Windows environment. There are several excellent Dragon emulators. These tools attempt to bridge the gap between these emulators and the host Windows environment.
The Microsoft Windows .NET 4 framework must be installed to use these tools. The .NET framework can be downloaded through Windows Update or from the http://www.microsoft.com site.
The following tools are currently included:
DragonDos
Permits accessing DragonDos filesystem in virtual diskette images. The VDK and DSK virtual diskette formats are currently supported.
Refer to the wiki at https://github.com/rolfmichelsen/dragontools/wiki for full documentation of the tools. This site also hosts the source code for the tools.
DragonDos 0.4.0.0 - Tools for accessing DragonDos virtual filesystems
(C) Rolf Michelsen, 2011-2013
Usage: DragonDos COMMAND COMMAND-ARGS [ OPTIONS ]
Commands:
check <diskimage>
create <diskimage> [<tracks> [<sectors>]]
dump <diskimage> <track> <sector>
delete <diskimage> {<filename>}
dir <diskimage>
freemap <diskimage>
read <diskimage> <filename> [<local filename>] [-ascii]
read <diskimage> <filename> <tape image>.CAS [<local filename>] [-ascii}
write <diskimage> <filename> [<local filename>] [-basic] [-native load start]
write <diskimage> <filename> <tape image>.CAS [<localfilename>]
Options:
-d Enable debug output.
-v Enable more verbose operation.
Visit http://www.rolfmichelsen.com/dragontools for more information.
groovydrifter
Agradecido : 53 veces
Re: Dragon Tools. Editor de DSK y VDK
Mensajepor groovydrifter » 15 Feb 2016 02:49
No deja de tener una cierta sorna o chufla el hacer una herramienta para "Windows" para linea de comandos... meh... En fin, como siempre alguien hará lo que el programador original no ha hecho y programará un GUI
Y lo mas chistoso es que ademas de no traer un GUI necesita NET Framework 4
Volver a “Dragon”
