OS-9 LEVEL - I Version 2.0 Disk Image?
Commodoro
Re: OS-9 LEVEL - I Version 2.0 Disk Image?
Mensajepor Commodoro » 17 Sep 2013 17:34
Great!
Can you upload OS9 L1V1.2 from Eurohard to the repository?
I dont have a copy, and i would like to try it.
Gracias por el OS9L1V2.0.
Y otra cosa ¿el software mas usual de Os9 para dragon?, es un sistema que no he usado nunca.
RetroMan
Mensajepor RetroMan » 18 Sep 2013 22:36
Here is the original Dragon Data OS9 L1 V1.2 system disk.
Did Eurohard ever release its own version of OS9L1 V1.2?
Dragon Data Ltd - OS-9 System.zip
(78.74 KiB) Descargado 274 veces
Agradecido : 3862 veces
Mensajepor ron » 19 Sep 2013 09:58
RetroMan escribió:Here is the original Dragon Data OS9 L1 V1.2 system disk.
Thank You Retroman ! I really appreciate this kind of contribs, and about Eurohards OS9L1 V1.2
For the small business user, Eurohard intends to use OS-9 as the standard operating system. "Flex," said Eduardo, "is a very British product and is not found elsewhere." OS-9 on the other hand is "fairly widespread and through it we hope to introduce people to UNIX".
http://en.wikipedia.org/wiki/FLEX_%28op ... _system%29
From April 1985, Dragon life was constantly good then bad. Compusense
announced that the new machine would have 128K RAM and run OS9 Level II as
an operating system and they as the UK distributors would not be importing
the 2.8" tape drive. But that "Towards the end of the year, some fairly
attractive systems should be produced, especially if Eurohard put in the
networking system". The UK firm also confirmed that Eurohard had sold
20,000 machines in Spain before Christmas, and although January and
February were obviously slow, they were going to try a new marketing tactic
(in Spain) - door to door sales of the Dragon. My view is that this would
seem to be a joke - though obviously not
I think that Eurohard only managed OS-9 Level 1 V2.0, previous releases seems not , we could investigate that way
Commodoro
Mensajepor Commodoro » 19 Sep 2013 12:09
Thanks, Gracias
Agradecido : 664 veces
Agradecimiento recibido: 1016 veces
Mensajepor dancresp » 21 Sep 2015 11:12
El viernes estuve probando el OS/9 en el emulador y la verdad es que me he quedado bastante flipado con las prestaciones de este sistema operativo, y como no, de su presentación en pantalla en 52 columnas.
Dicho esto, lo fantástico sería probarlo en la máquina real.
Así, ¿ cómo se puede pasar la imagen a un disquete de 3,5" ?
Y hay una cosa que no consigo, ¿como ejecuto el BASIC09 con el emulador Xroar 0.31.1? Y eso que lo monto en la unidad 1, y en la 0 tengo el del sistema operativo.
Y ya puestos, ¿una imagen del disquete "limpia"? al hacer DIR aparecen un par de ficheros que no se si es normal que estén allí (carta2) y que aparentemente están vacíos.
Mensajepor dancresp » 23 Sep 2015 00:07
Bueno, parece que ya me voy moviendo mejor con el OS-9 en el emulador.
La verdad es que había oído maravillas de este sistema operativo, y cierto es que cuesta creer que estés usando un DRAGON con 64 KB. -shock
En breve, novedades, y si alguien me explica como pasar las imágenes a disquete, agradecido.
