POR FIN !!!!Ha progresado Takeda Toshiya en el emulador del FP-1100
Y ahora sabe leer imagenes de floppy el emulador, incluso CP/M !!!
Da gusto, si senor
POR FIN !!!!Anna Wu escribió:@dancresp
About which SHARP MZ-80B are you talking and what you want save?
Anna Wu escribió:Takeda-san released a new Common Source Code Project update (2/21/2015)
http://homepage3.nifty.com/takeda-toshiya/
eFP-1100 is updated
[FP1100] improve auto key timing after shift key is pressed or released
[FP1100] fix crtc horizontal frequency
[FP1100] support cmt
[FP1100/MAIN] support wait for i/o access
[FP1100/SUB] support cmt control circuit consists of some standard logic ics
[FP1100/SUB] support vram plane mask
dancresp escribió:Anna Wu escribió:@dancresp
When I boot the computer in CP/M and modify the contents of the disk, erasing files for example, and type DIR, the content is correct.
But if I boot with the same floppy, changes I have made are lost.
I have not tried to use the tape...
Welcome to RW !!!
