CosmosEX para Atari ST. Mutilproposito con Raspberry Pi
Agradecido : 2317 veces
Agradecimiento recibido: 2104 veces
Mensajepor ron » 18 Oct 2014 23:55
CosmosEx neceista una Raspberry Pi para chutar. El invento tiene una pinta estupenda.
CosmosEx es un dispositivo para ordenadores Atari ST que sustituye varios periféricos en una única caja.
De momento desconozco el precio pero la web oficial es esta: http://joo.kie.sk/?page_id=384
Para apuntarse a comprar uno es esta otra: http://joo.kie.sk/cosmosex/buy/
http://www.youtube.com/watch?v=iKSLluG5ErE
http://www.youtube.com/watch?v=DD9wgUeAyLA
Features
serves as hard drive with SD card: the device has a single SD card slot which replaces a hard drive just like UltraSatan or SatanDisk
serves as hard drive with USB media: just insert a USB drive to USB slot and use it as a hard drive
serves as hard drive with shared folder from PC: use shared folder from other computer through network, map it to TOS drive letter – for easy transfer between your ST and PC in plain TOS (MiNT not needed).
serves as floppy emulator: loads .st and .msa images from connected media (e.g. usb key). Just select up to 3 images in the floppy image pool and switch between them using hardware button (more image formats will be added soon)
downloading of floppy images using simple tool from internet directly to the device (something similar to some app store) – play old games just after few clicks
can replace your keyboard, mouse and joysticks: just plug in a USB keyboard, mouse or joysticks to USB slot and you can use them with your ST (just like you would with Eiffel interface). But the best news is that you don’t have to replace all of them if you need only some of them – use USB joystick and USB mouse along with your original keyboard (or any other combination) – the USB peripherals are injected in the original peripherals data stream. No driver on ST needed, so this will work with games, too!
one metal case version of the device: the device can be used from outside of your computer or can be put in the place of internal floppy drive.
configurable from ST using a simple application
software updates available through network – one click update from the configuration application
Features that are planned for later
network driver – a lightweight Stick / Sting replacement, most of the network processing will be done in the device, the network speed will be much higher than any other current network solution for ST
support for opening ZIP files in TOS just like any other folder (in translated drive mode)
can you think of some other interesting feature? Let me know, maybe I’ll add it to this list ;)
can you do C and assembler on ST, or C and linux stuff, have spare time, want to see these features sooner? Well, you can help me with the work – contact me and I’ll give you stuff to do.
http://www.youtube.com/watch?v=CTMwjHtlmMg
Agradecido : 114 veces
Agradecimiento recibido: 127 veces
Re: CosmosEX para Atari ST. Mutilproposito con Raspberry Pi
Mensajepor DyLucke » 19 Oct 2014 01:08
Ya se hablo de ello si no recuerdo mal. Jookie tiene la produccion parada. Hubo ciertos problemas con la primera serie. Si tienes ya una Pi modelo B, el cacharro sale por unos 80 euros.
Mensajepor DyLucke » 19 Oct 2014 01:10
En cuanto vuelva a ponerse en produccion me pillare una... A ver si Jookie me avisa... Aunque con el lio que lleva mejor estar atentos al hilo en atari forum
game0ver
Mensajepor game0ver » 20 Oct 2014 19:28
No me digas! yo me hice con una y a día de hoy todavía no he tenido tiempo de probarla.
Se sabe cuales son esos problemas?
Mensajepor DyLucke » 21 Oct 2014 02:31
Mensajepor DyLucke » 21 Oct 2014 02:33
Mensajepor ron » 22 Oct 2014 20:12
¿ Te refieres al CosmosEX o a la Rpi ?
Mensajepor DyLucke » 23 Oct 2014 00:53
Volver a “Atari ST”
