ZEsarUX 9.1
chernandezba
ZEsarUX 9.1
Mensajepor chernandezba » 26 Nov 2020 20:21
Nueva versión estable de ZEsarUX 9.1 :)
Encontrarás, como siempre, versiones compiladas para Linux, FreeBSD, Mac y Windows.
El código fuente está disponible, como siempre. Recuerda que ZEsarUX es software open source, licenciado bajo GNU GPL, y gratis!
Esta nueva versión viene con correcciones en QL y TBBlue (Spectrum Next), mejoras en el menú, emulación de General Sound y mucho mas!
Descárgalo desde:
https://github.com/chernandezba/zesarux ... es/tag/9.1
Los cambios son:
Version 9.1 - Toi Acid Game edition. 26 November 2020
Added pc speaker audio driver (for Linux only)
Added General Sound emulation
Added compile setting to disable networking functions
Added date & time field info to ZSF snapshots
Added configuration & command line setting to save keymap type
Added some file converters: from SNA, SP, Z80, P, ZSF to SCR
Improved QL emulation:
-Added sound emulation
-Guessing of file name extension
-Show all registers on Debug CPU window
-Support ZSF snapshots
Improved TBBlue emulation:
-Added emulation of tbblue joystick type (register 5)
-Added sprite zoom emulation
-Added relative sprites emulation
-Added sprite clipping emulation
Improved ZX Desktop:
-Added direct buttons, to access menu items
-Added devices buttons/icons, to show device activity and device configuration
-Added F-key to close all open menus
-Reordered menu items
-Windows are not closed when changing ZX Desktop size
-Added new ZX Desktop fill types: RainbowAlive, Chess, Grid, Random
-Improved input number windows: added buttons to increase/decrease values
-Now backgrounded windows can be seen even with menu closed (added a setting and also a F-key)
Improved ZRCP:
-Added MMU information to cpu-history and get-registers commands
-Added ZRCP command qdos-get-open-files: to get open files from QL QDOS
Improved debugging:
-Added debug console as a menu window
-Added MMU information when viewing cpu registers on terminal console
Improved Waveform window: Now can show left & right channels
Improved 1 bit resample audio filter
Improved loading .pok files: increased maximum pokes from 100 to 49152 pokes
Improved File Browser: added previews for screens (on .scr, .tap, .tzx, .pzx, .trd, .dsk, .sna, .sp, .z80, .p, .zsf)
Improved ZENG: Added setting to reconnect after retry failed sending
Fixed QL bugs:
-Fixed loading QL Superbasic programs when line lenght usually longer than 128 bytes
-Fixed loading executable files, can even exec/exec_w files without QDOS header
-Fixed system calls FS.SAVE, FS.HEADS, FS.HEADR, IO.FSTRG, IO.EDLIN, IO.FCLOSE, IO.DELET
-Fixed possible hang calling IO.SSTRG
-Fixed using QL system calls and A6 pointer offset used after previous Trap was not 4
-Fixed RTC emulation
-Fixed frame interrupt
-Fixed cursor flashing
-Fixed listing (dir) call
-Fixed reading keyboard when menu open
Fixed reading keys on SDL and X11 drivers with default keymap and machines QL, MSX and Spectravideo
Fixed panic when changing machines and having ZX Desktop windows opened
Fixed panic when initializing audio and video drivers
Fixed panic extracting tap when invalid block
Fixed restoring machine to msx, coleco, sg1000 and svi
Fixed showing last core frame time in Core Statistics window
Fixed easter egg and cyrillic characters
Fixed rendering ZX Desktop on startup
Fixed arranging ZX Vision windows when changing machine or disabling border
Fixed open error when extracting tap with Spectrum names with '/'
Some other minor bugfixes and improvements
Que lo disfrutes!
César
ZEsarUX
jgilcas
Agradecido : 15 veces
Re: ZEsarUX 9.1
Mensajepor jgilcas » 27 Nov 2020 10:17
Me flipan los emuladores y este es una pasada, bravo César!!
cpcbegin
Agradecido : 152 veces
Re: ZEsarUX 9.1
Mensajepor cpcbegin » 27 Nov 2020 20:17
Completísimo.
Telemach
Agradecido : 104 veces
Re: ZEsarUX 9.1
Mensajepor Telemach » 28 Nov 2020 18:31
Uno de los emus más trabajados y completos que conozco de cualquier plataforma. Gracias por mejorarlo y compartirlo!
Agradecido : 2322 veces
Agradecimiento recibido: 2111 veces
Re: ZEsarUX 9.1
Mensajepor ron » 28 Nov 2020 18:59
Yo creo que el espíritu de Minter está dentro de este ZesarUX, el emu es un cachondo. xD
Agradecido : 3813 veces
Agradecimiento recibido: 1537 veces
Re: ZEsarUX 9.1
Mensajepor minter » 28 Nov 2020 22:20
ron escribió:Yo creo que el espíritu de Minter está dentro de este ZesarUX, el emu es un cachondo. xD
Te aseguro que no hay ni una sola línea de código mío en ese emulador.
Hubiera metido un EasterEgg del PakuPaku!!! -507
El emulador es muy completo, caramba!!! -thumbup
chernandezba
Re: ZEsarUX 9.1
Mensajepor chernandezba » 29 Nov 2020 22:35
Gracias por los piropos!!
No entiendo eso del espíritu de Minter XD
Lo que si que puedo decir es que ZEsarUX tiene Easter Egg... hasta 3 tiene en total! ;)
ZEsarUX
