MiSTery. Imagen para MiST -Atari ST- basada en Predator SATAN
Agradecido : 195 veces
Agradecimiento recibido: 627 veces
Mensajepor Estrayk » 30 Ago 2019 00:52
Aprovechando que hace pocos días que slingshot anunció un nuevo core cycle accurate de -j4tar1 ST llamado MiSTery, he actualizado la imagen que hicimos para las SATAN, la he montado y preparado para MiST.
La recopilación esta actualizada sobre la imagen Predator que ya hice para las SATAN aquí:
http://retrowiki.es/viewtopic.php?f=39&t=904
ATARI ST IMAGEN RECOPILACIÓN PREDATOR V1.5 (MiST version)
Añado...
DEMOS:
Midnight Sun by Dead Hackers Society STE
Execution by SMFX ST
Glokzilla by MJJ Prod ST
Bad Apple!! by fenarinarsa STE
Raiders of the Lost Duke by Hemoroids STE
rise of the blackstorm by mystic bytes STE
Revise And Revisit by Dead Hackers Society STE
No Pigs and Mosquitos by Dead Hackers Society ST
Krets by Dekadence ST
Recycles by SMFX ST
Motus by SMFX ST
MUSIC / TRACKERS
Checktrakk - the YM2149 tracker made by Checkpoint
StarTrack by Newline
Audio Sculpture V1.5 Beta by SYNC
GAMES
R0x Zero by Retro Gamer
Supa Zazai Da by Cerebral Vortex
Chambers of Shaolin
Enchanted Land
Lethal Xcess
Panza Kick Boxing
New Zealand Story
Fire and Brimstone
Badlands
Elimino...
GRAPHICS.2D
ChromaStudio, solo para Falcon
Actualizo...
MUSIC / TRACKERS
maxYMiser V1.34 High
GAMES / _SCENE
Pole Position
OIDS
Y muchas mas cosas que no he apuntado....
No olvidéis actualizar la MiST a la última version de firmware:
https://github.com/mist-devel/mist-bina ... r/firmware
Y usar la ultima version del core mystery:
https://github.com/mist-devel/mist-bina ... es/mistery
Cycle accurate STe GLUE+MMU combo (re-created from the original schematics)
Cycle accurate FX68K CPU core
Mostly cycle accurate shifter based on schematics made from reverse engineering
MegaSTe 16 MHz CPU mode
RAM size up to 14MB
Support for all TOS versions
2 Floppy disc drives
ACSI hard disc support
Viking compatible hi-res monochrome card support
Real IKBD with HD63701 MCU
Real MIDI input/output using MiST's UART pins
Serial/parallel port redirect to USB
Gauntlet type 4 joystick interface support
Optional scandoubled/YPbPr video output
Configurar el Mystery con TOS2.06 Spanish, 4Mb, STe o MegaSTe.
Contenido Oculto
Os recuerdo que la implementación del Blitter no está acabada y muchas demos y juegos para STE usan el Blitter. Esperemos que en breve se acabe de afinar.
alberchi
Agradecido : 22 veces
Re: MiSTery. Imagen para MiST -Atari ST- basada en Predator SATAN
Mensajepor alberchi » 30 Ago 2019 08:40
Voy descargando... ¿ Es para grabarla en una SD independiente o es una imagen de disco que se monta desde el core ?
Agradecido : 196 veces
Mensajepor Jinks » 30 Ago 2019 09:43
Me lo has quitado de la boca, iba a preguntar justo eso mismo. He leído "SATAN" y "core" en el mismo post y estoy confuso :roll:
¿Es para poner en una unidad Satan en un ST real, o es para la MiST? (con lo que debería incluir el core)
¿O la misma imagen tiene los dos usos?
Mensajepor Estrayk » 30 Ago 2019 13:04
Es un fichero que puede ser usado en MiST, MiStica, MisTer (cuando haya core), Hatari, Raspberry pi..etc....
shanshe
Mensajepor shanshe » 30 Ago 2019 13:13
Muchas gracias por la imagen!!!
El otro día en un directo de Ron, decía que al sonido le pasaba algo en este core. En el video no parecía mucho ruido pero ahora que lo acabo de poner... Dios que mal suena el turrican 2, al menos en la intro, en el juego no se nota tanto. (Todavía no he probado ninguno más, con lo que no se si he ido al peor de los casos, si es así, vaya puntería...).
Agradecido : 2136 veces
Agradecimiento recibido: 1913 veces
Mensajepor ron » 30 Ago 2019 18:05
Quítate el filtro Stereo al YM, el sonido mejora ostensiblemente.
Mensajepor ron » 30 Ago 2019 19:24
Adjunto un programa que al bueno de estrayk se le pasó añadir....
Montáis la imagen .ST en A: y copiáis el .PRG al directorio Homebrew. Entonces la imagen ya es perfecta. -drinks
MMINER.ST.zip
(106.43 KiB) Descargado 26 veces
-grin -507 -rofl
Mensajepor ron » 30 Ago 2019 19:49
y para celebrarlo... a partir de las 20 horas en Marte, retrocrypta.
En Twitch: https://www.twitch.tv/events/0RwsggxjT7-CuqqamHpyYg
Y la RetroCrypta en Twitch: https://www.twitch.tv/retrocrypta
-grin -shock -thumbup -drinks -rofl -507
Telemach
Agradecido : 83 veces
Agradecimiento recibido: 16 veces
Mensajepor Telemach » 31 Ago 2019 13:14
Gracias Estrayk por otro gran aporte y a Ron por acordarse de los más veteranos... -grin
Como siempre falta tiempo pero lo probaremos. Aún no he conseguido usar el Hatari para "editar" esas imágenes. Que pena que con el IMdisk no se pueda.
Para cuando un crowdfunding para recrear esa belleza virtual que encabeza el post? -507
edison658
Mensajepor edison658 » 10 Sep 2019 20:29
Gracias por el trabajo, pero archivo eliminado...
Mensajepor Estrayk » 10 Sep 2019 22:34
Sí, el archivo lo he eliminado porque estoy haciendo un versión nueva ya que ésta tenia un bug en la tabla de particiones. darme un par de días y lo subo
edison658
Mensajepor edison658 » 11 Sep 2019 15:56
ok ok buenas noticias.
Tu eres el mismo Estreyak que hizo música con amiga computer?
Mensajepor Estrayk » 12 Sep 2019 01:01
Version 1.5
He rehecho todo el disco duro porque la imagen anterior tenia un problema con la tabla de particiones y el driver de Peter Putnik me ha dado mas dolores de cabeza que alegrías. Ahora la imagen lee mucho mas rápido, está con el mejor y mas rápido driver de disco duro para Atari ST, el HDDRiver de Uwe.
He aprovechado para meter el Manic Miner, he actualizado algunos juegos como el LOOM y un montón de cosas mas.
Ah! Y algunas aventuras en castellano de Aventuras AD: La Diosa de Cozumel, Los Templos Sagrados, La Aventura Original, Jabato, Chichen Itza...etc
espero que la disfrutéis.
Un saludo!
Contenido Oculto
Mensajepor ron » 12 Sep 2019 07:14
Grande Estrayk. Muchas Gracias
edison658
Mensajepor edison658 » 12 Sep 2019 17:59
Muchas Gracias Estrayk
Mensajepor Estrayk » 26 Sep 2019 01:11
IMAGEN SATAN ATARI ST V1.6 (Septiembre 2019) Por Estrayk.
ChangeLOG:
>>> AÑADO <<<
Lattice C 5.6 (Gracias por el aviso Explorer)
La Diosa de Cozumel (Gracias a Poliyo)
Los Templos Sagrados (Gracias a Poliyo)
La Aventura Original (Gracias a Poliyo)
Jabato (Gracias a Poliyo)
Chichen Itza (Gracias a ElDelCairo)
Bargon Attack (Gracias a frjagose)
SPECTRUM EMULATOR 2.07
SPECTRE GCR 3.0
>>> ACTUALIZO <<<
CALAMUS ESPAÑOL (Gracias a tito teclado)
Loom Castellamo FULL crack 100% (gracias a crashman)
Everest - registered (gracias a tito teclado & Explorer)
Aegis Animator de 2.07 a la 2.11
y muchas cosas mas...
Contenido Oculto
