ZEsarUX Beta 8.0 Release Candidate
chernandezba
Agradecimiento recibido: 150 veces
Mensajepor chernandezba » 09 Jul 2019 11:38
Hola!
He subido una nueva versión BETA de ZEsarUX, la 8.0 Release Candidate. Esto quiere decir que en breve llegará la versión estable :)
Podéis descargarla, como siempre, desde la dirección:
https://github.com/chernandezba/zesarux/releases
Hay versiones compiladas de Linux, Mac y Windows. También está el código fuente disponible.
La lista de cambios de esta versión:
Version 8.0 Beta-Release Candidate. 9 July 2019 - World Destruction edition
Improved menu interface:
-Program Window can be extended horizontally and have a right region to place menu zxvision windows (called ZX Desktop)
-Draw engine: now it allows transparency
-Menu windows can be placed and resized to the whole program window
-Some windows geometry (position, size) are saved in the configuration
-Hotkeys now show right capitalization (lowercase or uppercase)
-Edit box now has a key to delete all input (cursor down)
-Edit box can now move cursor left and right and write text in the middle
-GUI color bars depend on current style
-Added support for more cyrillic characters on menu
-Added RetroMac Gui Style
-Improved footer:
--Footer now completely follows GUI Style
--Reordered cpu use, numbers in red when cpu use > 85%
--Now shows cpu temperature on Linux (and not only on Raspbian as before)
Added Real time playback from AY Chip sound to external MIDI device
Added menu to export AY chip music to midi (.mid) file
Added AY Sheet: showing a sheet with the notes being played
Added AY mixer menu
Added DAAD, PAWS and Quill debugger, for Spectrum and CPC (CPC only supports Daad debugger)
Added text adventure keyboard also on CPC
Added colors to ncurses driver and Chloe machine
Added Chloe MMU to ZX-Uno
Added Derby+ and Derby++ roms
Added hdf to ide/mmc raw converter
Added hdf support to MMC emulation
Improved breakpoint parser:
-full expression parser: parenthesis, functions, sums, multiplications, etc. Can be used as a full calculator!
-now it's a lot more faster. Up to 7 times faster, so it uses 7 times less cpu than the old version
Improved watches:
-using new expression parser
-up to 10 watches on screen
-watches are saved on configuration file
Improved Adventure Text Extractor: now it supports Daad games too. So it supports Daad, Paws, Quill and Gac
Improved Visualmem: now you can see all 3 different access (write, read, opcode) at once, generating a RGB color
Improved Waveform window: now the wave adjusts automatically to the zxwindow size
Improved Hexadecimal editor: now it resizes view to zxwindow height
Improved TSConf layers menu: Added "reveal" setting to view which pixels are used by a layer
Improved Scale 0.75 function: now it has antialias
Improved Cpu Transaction Log: now logfiles can be rotated automatically
Fixed Pentagon interrupt handling: now effects on border and hi-res work almost perfect!
Fixed interrupt bug behaviour where last opcode lasts >=32 t-states and interrupt in the middle
Fixed "Jeff Braine" manufacturer to "New Horizons". Changed Prism machine name to "Prism 512"
Fixed bug having more than 256 text to adventure keyboard words
Fixed bug on CPC vertical scrolling
Fixed segmentation fault bug when drawing CPC machine
Fixed segmentation fault bug when displaying first aid messages
Fixed bug redrawing zx80/81 display, with realvideo disabled, and menu char width less than 8
Fixed bug drawing menu window boxes when char width less than 8
Fixed zxvision left button handling: no longer sends enter when the user is dragging the window
Fixed machine names to be completely right: for example, "Spectrum 48k" becomes "ZX Spectrum 48k", etc
Fixed saving sprites when memory zone is not default zone
Fixed bug when writing divmmv memory on Chloe machine and underlying RAM in space 0000-3fffh become overwritten
Fixed bug crash when a message error was generated from ZRCP and menu had a tooltip open
Espero que lo disfrutéis :)
César
ZEsarUX
Agradecido : 190 veces
Re: ZEsarUX Beta 8.0 Release Candidate
Mensajepor Jinks » 10 Jul 2019 23:34
Pero, ¿cómo lo haces?
Si solamente escribir la lista de novedades ya te tiene que llevar la tira de tiempo...
Por cierto... ¿"World Destruction edition"? :)
Agradecido : 2985 veces
Agradecimiento recibido: 1261 veces
Mensajepor minter » 11 Jul 2019 13:01
"Improved Adventure Text Extractor: now it supports Daad games too. So it supports Daad, Paws, Quill and Gac"
Me mola esto! :)
chernandezba
Mensajepor chernandezba » 13 Jul 2019 13:18
Jinks escribió:Pero, ¿cómo lo haces?
Jajaj bueno realmente cada vez que programo algo lo agrego a la lista de cambios, no los redacto todos de golpe, por lo que el trabajo es progresivo ;)
Si, World Destruction. Una joya de Ventamatic que conseguí hace muchos años y siempre me ha gustado, creo que es un poco desconocido y es un muy buen juego. Esas patadas de Karate son una pasada...
http://www.worldofspectrum.org/infoseek ... id=0005739
Cada versión de ZEsarUX suele llevar un nombre en clave de mis juegos favoritos, y esta vez le ha tocado a ese. Por cierto que el juego viene incluido en ZEsarUX aunque está un tanto oculto, hay que encontrar uno de los Easter Egg de ZEsarUX para poderlo jugar ;)
César
ZEsarUX
chernandezba
Mensajepor chernandezba » 13 Jul 2019 13:21
Me mola esto! :)
Pues si, es capaz de crear una ventana con una lista de palabras que se usan en el juego y las puedes elegir a golpe de ratón.
También incluye otra característica avanzada para poder debugar dichas aventuras conversacionales (en ese caso soporta juegos hechos con Daad, Paws o Quill)
Gran parte de este trabajo ha sido gracias a uto (Carlos, muy activo en los grupos de aventuras conversacionales)
César
ZEsarUX
Agradecido : 2205 veces
Agradecimiento recibido: 676 veces
Mensajepor Chema » 13 Jul 2019 13:30
chernandezba escribió:
Me mola esto! :)
César
Coincido en que mola. Mola mucho.
