ZEsarUX 6.1 BETA Marzo 2018
chernandezba
Mensajepor chernandezba » 13 Mar 2018 18:35
Hola
He subido una nueva versión BETA de ZEsarUX. He migrado de Sourceforge a Github, esta nueva release beta se puede encontrar en
https://github.com/chernandezba/zesarux ... 1-13032018
Como otras beta, hay versiones ejecutables para Windows y Mac. Los usuarios de Linux y otros sistemas operativos, deben compilar de código fuente
Las últimas versiones estables 5.0 y 6.0 ya se han movido a Github. Otras más antiguas aún están en sourceforge pero pronto las moveré también.
Cambios desde la última beta de Enero:
Added improved Spectrum 16/48/+ colour palette
Added setting to add a watermark on the display
Added setting to reduce display to a factor of 0.75. Used on RunZX event
Added TSConf DMA emulation, line interrupt, sprites layers
Added ZX Recreated keyboard support for Linux, Mac and Windows
Improved frameskip: now realvideo buffer is not updated when frameskip
Improved ZRCP: run command is stopped by default when pressing a key (or sending data to the socket)
Improved TSConf rendering: now tiles and sprites are drawn per scanline. Border drawing. Handling of scroll registers
Improved TSConf debugging: debug for DMA, Video registers, Video layers, Sprites, Tiles
Improved text mode drivers (aalib, stdout, simpletext, curses): text settings are in different submenu, setting to set stdout/simpletext fps
Improved smartload: now the cursor remembers last file loaded
Improved sprite viewer:
*now can see sprites with speccy screen format
*you can view sprites up to 512x192
*you can see tsconf sprites
Improved configuration parsing: if unknown setting found on configuration file, ZEsarUX will open but warns about the error, and the autosave feature is not enabled
Improved TBBlue emulation: Added clip window registers
Improved rendering on text mode drivers: now realvideo mode can render directly to black&white text. Try TSConf with --vo stdout --realvideo --autoredrawstdout
Improved Linux library dependencies: libssl is not enabled by default on compilation
Fixed some crashes with speech enabled and opening some menus: AY Registers, AY Player, etc...
Fixed annoying sound on Dandanator rom menu
Puedes ver la lista de cambios completa aquí:
https://github.com/chernandezba/zesarux ... /Changelog
Espero que os guste :)
César
ZEsarUX
Agradecido : 936 veces
Re: ZEsarUX 6.1 BETA Marzo 2018
Mensajepor minter » 13 Mar 2018 22:17
improved everywhere! -507
chernandezba
Mensajepor chernandezba » 14 Mar 2018 10:11
jaja pues si, tengo que buscar un sinónimo para no repetirme tanto :)
Pero si, hay muchas cosas que ya existían y que se han mejorado
ZEsarUX
sabreman
Mensajepor sabreman » 14 Mar 2018 13:53
Gracias, voy a echarle un vistazo !
