Saludos,
El fin de semana obtuve dos C=64's (breadbin y 64C). No tengo la unidad 1541 y realment no me interesa. Necesito un cartucho que lea las imagenes floppy y tener Ethernet para acceso a BBS. Realmente no se que mas podria utilize de estos cartuchos. Mi pregunta es cual de los cartuchos es preferible? El ultimate II+L me parece un poco caro y el TeensyROM tiene un costo mas favorable.
Gracias..
¿ultimate II+L vs TeensyROM?
- marcos64
Re: ¿ultimate II+L vs TeensyROM?
El TeensyROM no parece leer D64, asi que ni siquiera es una opcion.
TeensyROM Features
Compatable with C64 and C128 machines/variants, NTSC and PAL supported
Super fast Loading (.PRG/P00) or ROM emulation (.CRT) directly from:
USB thumb Drive
SD card
Teensy Internal Flash Memory
Transfer directly from PC using the TeensyROM UI
See supported file details here
NFC Loading system available to quickly select/load with NFC tags.
MIDI in/out via USB Host connection:
Play your SID with a USB MIDI keyboard!
Use with popular software such as Cynthcart, Station64 etc, or the included MIDI2SID app
Supports all regular MIDI messages in and out
Can use your C64 to play a MIDI sound capable device.
Sequential, Datel/Siel, Passport/Sentech, and Namesoft MIDI cartridges emulated
Use a USB Hub for multiple instruments+thumb drive access
MIDI in via USB Device connection:
Stream .SID or .MIDI files from a modern computer directly to your Commodore machine SID chip!
Play MIDI files out of your PC into C64 apps such as Cynthcart or the MIDI2SID app
Stream .SID files out of your PC using the ASID MIDI protocol to hear any SID file on original hardware.
Internet communication via Ethernet connection
Connect to your favorite C64/128 Telnet BBS!
Use with released software such as CCGMS, StrikeTerm2014, DesTerm128, etc
Swiftlink cartridge + 38.4k modem emulation
Send AT commands from terminal software to configure the Ethernet connection
Sets C64 system time from internet
Firmware updates directly from SD card or USB thumb drive
Just drop the .hex file on an SD card or USB drive, no need for extra software to update.
Key parameters stored in internal EEPROM
Startup, Ethernet, timezone, etc retained after power down.
VIC20; 64,C,Aldi; 16; 500
- Pow!
SD2IEC es barato y se sirve para lo que quieres hacer.
- masteries
FerociousAmiga escribió: ↑15 Jul 2024 07:48 Saludos,
Gracias..
Tal vez te pueda interesar un Meatloaf-Fujinet; a través del Wifi te conectas a BBS, un chat, cargar .D64 desde internet e incluso hay un navegador web (que permite ver páginas que han sido creadas especialmente para el propósito de verlas en ordenadores de 8 bits, no puedes ver cualquier página web).
Desde la tarjeta SD carga perfectamente los ficheros .D64;
lo que no hace todavía es cambiar de disquete/cinta; por ejemplo si un juego te pide que introduzcas la segunda cinta o el segundo disquete en la unidad, pues no podrás cambiar y eso para mí si es una limitación.
Respecto a los Meatloaf-Fujinet estoy pendiente de presentarlos en sociedad.
Respecto al precio, serían baratos, en torno a 38€ - 40€ con caja (de verdad, no impresa 3D) y su cable para el puerto IEC.
Pero estoy esperando a ver si pueden añadir lo del cambio de discos/cintas.
La maestría interior...
Gracias a todos por las repuestas. Analizando los costos y las opcciones que necesito, el pi1541 parece que va hacer mi mejor option. Utiliza un Raspberry Pi Zero o RPi 3. (USD $40 - $136)
https://cbm-pi1541.firebaseapp.com/
-SD2IEC problema con compatibilidad. (USD $35 - $70+)
-TeenyROM hace bastante pero no emula la unidad 1541 y no tiene supporte *.D64 y otro formatos. (USD $70+)
-Ultimate II+ hace de todo pero my caro. Emula 1541 y supporte *.D64. (USD $160+)
-Meatloaf-Fujinet muy interesante.
EDIT:
-Turbo Chameleon 64 V2 ??? (USD $257+)
-Tapuino Emulador de casetero, .TAP (USB $40+)
-TapuinoNext (Alpha)
-Kung Fu Flash Emular diferentes cartuchos con supporte para CRT, PRG o D64. (USD $25+)
EDIT:
- sharklodon
La Ultimate es la caña. Para mi es el dispositivo "único" para nuestros c64, no necesitas más. Vale la pena la inversión, si sumas que si pi1541, tapuino, etc... ya se te va todo de madre superando el precio de la Ultimate.
Saludos,
Shark
Saludos,
Shark
TRS-80 - FPGAs: MiSTer Poseidon ZXTres++ Atlas DE-10 Lite
- monoceross
Tengo kung fu flash (para cargar es la caña) y SD2IEC para guardar en BASIC como si fuera un floppy. Antes cargaba con el segundo, tarda mas, pero funciona bién
10 NEW
RUN
READY
_
RUN
READY
_
Gracias sharklodon. Aqui vi un ejemplo que la combinacion de dispositivos para hacer lo mismo que hace el UII+ costaria sobre los USD $350+
https://c64os.com/buyersguide/1541UltimateII
Gracias monoceross voy a revisar.
