I have the go ahead from Frank to post the Danish upgrade documentation, Frank says he is working on an English translation among many other exciting things.
here are just a few pages to give you an idea what is in this treasure trove...
http://www.retrogubbins.co.uk/downloads ... grade-docs
20MB download
The Danish Hardware Upgrades and Danish Group ROM
- Agradecido : 311 veces
- Agradecimiento recibido: 861 veces
Re: The Danish Hardware Upgrades and Danish Group ROM
I've "deciphered" the 6Mhz mod and I'm near to try it. Seems to need only the following steps:
1) Replace original Z80 with a faster version
2) Isolate IC9 - pin 13
3) Wire IC9 - pin 13 with IC19 - pin 6
4) Isolate IC68 - pin 6
5) Wire IC68 - pin 6 with IC19 - pin 5
Note: The drawing doesn't shows any modification, it's the original Lynx clock schema.
The mod is something like this:
Is the above correct?, it has been ever tested?. Although it doesn't looks a harmful modification, I don't want to ultimately risk my Lynx...
