Página 1 de 1
CoCoDskUtil [ Tool Dragon / CoCo para Discos y más ]
Publicado: 15 May 2011 22:18
por ron
Uno de los nuevos usuarios, luis46coco, ha creado esta herramienta que es impresionante.
Si tienes un Dragon o un CoCo , y no la conocíais estáis de enhorabuena porque es una herramienta que os hará la vida mucho más fácil.
http://luis45ccs.blogspot.com/search/label/CoCoDskUtil
Cualquier imagen de disco de CoCo o Dragón: Permite ver y editar cualquier contenido de las imágenes de disco, conversiones ASCII, BIN, visualizar contenidos, programas, hasta gráficos en formato COCOMAX.
Un montón de posibilidades, que según nos ha contado luis45ccs, permitirá seleccionar un BAS o un BIN de una imagen de disco y lanzarlo a un emulador o a una máquina original a traves de Audio / Cassette.
This utility checks multiple virtual disks (one at a time) of the Color Computer *. DSK, VDK (DRAGON) and displays its directory
It is easy to move from one disk to another and revise many well.
- Go to the directory
- View files in various ways, PC and DSK (RS-DOS)
- View Sectors and Tracks
- Copy files from PC to COCO (RS-DOS) and vice versa
- Format, Create empty disk DSK
- Sort alphabetically or by another order virtual disk DSK.
- Check FAT errors
- Format coco, green characters on TV As the coco (to remember).
- Convert BIN Basic programs to ASCII format and vice versa, both within the DSK and PC (DIR separate files on the PC)
- Views and editing in DSK and PC.
- View and edit in HEX and DSK.
- Delete files on DSK and PC.
- Rename (name and extension) in DSK.
- Change attributes, types and formats.
- Sort by name, size granules, and Bytes, Etc. first pellet up and down, and several at once.
- English and Spanish languages, expandable
- Copy PC to DSK and vice versa by dragging and dropping.
- View VDK (DRAGON) read-only
- View pictures and files COCOMAX
- View graphic sectors and tracks
COMING SOON
- OS9 and NITRO, 40 track, 80 track and DD, large disks
- Desfracmentar
- Compare many. DSK and see if there are duplicate programs. adding into each other.
- Use of granules, for reconstruction or deleted files
- Run programs with the emulator
- Print a copy of a DIR or TXT.
- Editor of sectors (disk and file)
- Recover deleted files, damaged or corrupted
- Show errors (almost)
- Moving from Wav to Cas and vice versa.
- View Graphic Pac and other formats, databases and so on., If anyone has knowledge and information of the subject, will welcome
- Copy files from one disk to another
- Maybe disassemble
- What is needed
- The sources I can give at the end, so that no duplicates with changes there.
The idea is that I ask for them, for now, and if I can the please
Setup Multi language
Setup Español(Win vista y 7)
4shared.com/file/QpgWiue7/CoCoDskUtilPack.html
Re: CoCoDskUtil [ Tool Dragon / CoCo para Discos y más ]
Publicado: 15 May 2011 22:20
por DyLucke
la caña, muy util para quien quiera desarrollar algo, o incluso hackear algun programa. ^^
Publicado: 15 May 2011 22:25
por ron
Actualmente según las posibilidades ( infinitas ) que da este programa, podemos extaer el BAS o el BIN de una imagen de disco al PC y pasarlo a CAS mediante PCDBIN para cargarlo en una máquina real.
[Tools]
Tools World of Dragon/
PC/Dragon disk utilities
dg.com
Get file. Usage: dg filename. Retrieves file from DragonDOS disk.
dls.exe
Prints directory listing of DragonDOS disk.
dtocas.exe
Convert retrieved BIN or BAS file to CAS format. Usage: dtocas infile outfile loadname. Where loadname is the name of the program in the CAS outfile.
padcas.com
Pads a CAS file with leader bytes so that it is suitable to load into a Dragon (by plugging the cassette port into the sound card). Also means COCO2-1x ca n read it without an IO ERROR.
Publicado: 15 May 2011 22:34
por ron
Es fantástico...
Del mismo disco del Manic Miner,
5 ' JSW-GAM
10 PCLEAR 1:CLEAR 200,&H180
14336 RUN"DISABLE.BIN"
30 LOAD"JETSE
18766 "
40 GOSUB 200
50 POKE &HFF48,0
60 POKE &H1A0B,&H21
70 POKE &H2CC0,
9363
8230 H71,0
90 EXEC &H1A03
0 CLS:INPUT"SCREENS TITLE";A$:IF A$="" THEN
9432
8776 OW MANY";N
220 X=&H33E
2048 FLREADFOR I=1 TO N:N$=STR$(I):N$=MID$(N
10496 %7
52041 *2+&H7530:POKE P,INT(X/2
14995  P+1,(X AND 255)
250 IF LEN(N$)
48928 N$="0"+N$:GOTO 250
260 PRINT:PRINT"LO
20039  ";A$;".";N$
270 LOAD A$+"."+N
15004
280 X=X+PEEK(1620)*256+PEEK(16
37 PCLEAR"NEXT I
300 RETURN
Publicado: 17 May 2011 01:05
por dancresp
Buena herramienta, si señor.
Lo que no me he puesto a buscar nunca son imágenes de disco de un Dragon. Siempre he ido a por ficheros CAS.
Publicado: 04 Sep 2011 14:58
por lafumat
vaya, vaya, lo que se descubre...
se nos amontonan los deberes , ron!!!
Publicado: 31 Ene 2012 12:23
por ron
He estado hablando con luis46coco, autor del programa para que añada unas pequeñas características y mejoras a ver si es posible.
Habrá que estar atentos esta herramienta es oro puro.
