Página 1 de 1
Behr-Bonz VIC-20 Multicart
Publicado: 21 May 2015 12:02
por Whisper
Alguien conoce esta cart para el Vic-20. Lo comento porque buscando un cartridge parecido a la Mega Cart para el Vic (imposible de conseguir), encontre esta, que aunque no parece tan sofisiticada como la otra, parece un digno sucedaneo. Se va a hacer una nueva remesa y el plazo para apuntarse parece que todavia esta abierto. Os pego un mensaje que he recibido cuando pregunte por ella aqui: enlace a Willcox.
Hello,
You have received this e-mail because you have expressed interest in purchasing the Behr-Bonz multicart. This cartridge designed for your Commodore VIC-20 computer comprises 127 games, all of which were originally published as game cartridges between 1981 and 1984. No additional expansion is required to play them, except a joystick and, depending on the game, a pair of paddles.
More details can be found in the related discussion topic on the Denial forum ( http://www.sleepingelephant.com/denial ) and the Lemon64 forum ( http://www.lemon64.com/forum )
The new Behr-Bonz will be slightly different from the Original with a new color in the menu and a button to reset to menu without the need to turn your VIC-20 off and on.
The Behr-Bonz multicart circuit board is exactly the same physical size as a Commodore made game cartridge so it can fit in the plastic case of a game you already own (4.5 x 9 cm). No plastic case is provided.
Just like original Commodore cartridges it uses gold plating to protect your cartridge port connector and for the longest possible lifespan. It is protected by a 90 day money back guarantee. Please note that out of the 100 original units made in 2008, not a single one was found to be defective nearly 7 years after their initial release.
You can now send your payment via paypal to eslapion@videotron.ca
Before sending a payment, please consider the following information:
-The price per unit of the Behr-Bonz multicart is 48$US. Quantity discounts are available on quantities of 5 units or more. Payments in canadian dollars are available to people living in Canada.
-Shipping to the US is 10$US, Australia, all EU countries and Canada is 11$US
- It is very important that you include your shipping address in the payment information section
-Shipping will begin at the end of june 2015 - if the production run is halted for any reason then paypal allows a full refund up to 60 days after sending a payment and all customers will get back their money.
- YOU MUST SPECIFY WETHER YOU WANT A PAL OR NTSC VERSION - if this information is not specified then I will determine it myself according to the video standard available in the country of the shipping address
Thank you for your interest and your support. If you like the Behr-Bonz multicart, please tell all your friends about it and tell them to get in touch with me.
A falta de la Mega Cart, bastante mas cara, imagino que buena será.
PD: los hilos en los foros lemon64 y Denial de este nuevo anuncio imagino que seran estos:
http://sleepingelephant.com/ipw-web/bul ... +Multicart
http://www.lemon64.com/forum/viewtopic. ... 26ce09a109
Re: Behr-Bonz VIC-20 Multicart
Publicado: 21 May 2015 12:47
por groovydrifter
Anda, pues yo tengo usuario en Denial y se me habia pasado. Yo me monté un Final Expansion... osea el numero de cartuchos simulados es TODOS y ademas trae ampliacion de ram y SD2IEC. Eso si... te tienes que currar tu el meterlos ahí y configurarlos... cosa que en otros cartuchos precocinados viene ya hecho. Este es algo mas barato que no está mal (48$ vs. 65€)
Publicado: 21 May 2015 13:12
por groovydrifter
Ufff... acabo de leer el hilo en Denial... yo paso.
Publicado: 21 May 2015 13:37
por wilco2009
GroovyDrifter escribió:Ufff... acabo de leer el hilo en Denial... yo paso.
No le veo mala pinta. ¿Qué problema le ves?
Publicado: 21 May 2015 17:41
por Whisper
GroovyDrifter escribió:Anda, pues yo tengo usuario en Denial y se me habia pasado. Yo me monté un Final Expansion... osea el numero de cartuchos simulados es TODOS y ademas trae ampliacion de ram y SD2IEC. Eso si... te tienes que currar tu el meterlos ahí y configurarlos... cosa que en otros cartuchos precocinados viene ya hecho. Este es algo mas barato que no está mal (48$ vs. 65€)
Yo tambien tengo la FE3....pero es un toston el tener que "currartelos". Ademas sino mal recuerdo las imagenes que puedes subir son solo de disquetes (D64) y no de cartuchos...
Publicado: 21 May 2015 17:44
por Whisper
+1
No he leido el hilo por falta de tiempo, ¿cual es el problema?
Publicado: 21 May 2015 19:29
por groovydrifter
Pues que es un sistema cerrado, 127 cartuchos y ya. Luego está el "no lo modifico porque cuesta 1000 dolares encargar el esquema y 500$ poner a punto las maquinas" que me suena a cuento chino, aunque pude que el trabaje así... pero a mi no me convence. Añádele el pagame 2$ por cada juego que no te guste y quieras cambiar... ¿en vez de darle el fichero, explicarle como va montado todo y pedirle que se lo monte el? no se, a mi no me convence.
Publicado: 21 May 2015 19:41
por groovydrifter
Pues no, puedes poner cartuchos, de hecho es perfecto en ese aspecto. El sistema de scripts con el que se montan los menus te permite cargar un fichero en memoria (una imagen de un cartucho) en la posicion que deseas y luego protegerla contra escritura y reiniciar la maquina todo de tirón. Luego es compatible con absolutamente todos los tipos de cartucho, de todos los tamaños salvo los que incorparan hardware específico (si ese hardware especifico no es ram, porque si es ram, tambien se puede)... luego puedes cargar juegos configurando la expansion de memoria para que el juego funcione previamente... Vaya, que el nombre de Final Expansion le viene al dedo.
http://koti.kapsi.fi/~jvaltane/vic20/fe ... Manual.pdf
Publicado: 21 May 2015 21:11
por ron
Es una pasada veros abrir hilos hasta de Vic20, mola mucho ! Creo que lo he conseguido. xD
A ver , estoy siguiendo el hilo con atención y estoy de acuerdo con groovy.
Finalmente ¿ un Final Expansion cuanto viene a salir ? ese si que me gusta.
Publicado: 21 May 2015 22:25
por groovydrifter
ron escribió:Es una pasada veros abrir hilos hasta de Vic20, mola mucho ! Creo que lo he conseguido. xD
Pues ahora mismo vale 59,99 + envio y los hay disponibles en venta:
http://www.sinchai.de/index.php?main_pa ... ucts_id=77
Supongo que sabras que es la tienda del usuario Donald, de forum64. En ese foro y en Denial habia (no se si seguiran estando) varios ficheros ZIP para ponerlos en tarjetas con casi todo configurado, algunos trabajos a medio hacer... pero con eso, para tener ejemplos practicos, y el manual que he linkado antes se puede hacer. Aviso que la edicion es en PETSCII
Aunque los gerber no los he encontrado disponibles, los usuarios mas inquietos encontraran que en Denial recreamos a partir de escaneos de la placa los esquemas, con algunas mejoras incluidas. Para montar este dispositivo hay que sacrificar un cartucho de vic 20, o bien adquirir una carcasa, pero en Sinchai.de ahora mismo, y desde hace un tiempo ya, no los hay.
En Sinchai.de hacen tiradas de vez en cuando, nunca muy grandes para no quedarse placas pilladas, porque al fin y al cabo es un usuario que pone ese medio a disposicion de quien quiera sacar sus proyectos. A lo que voy: el que quiera mas le vale espabilarse. En la propia pagian está el manual de montaje, en aleman todo. Yo he encontrado que traducir con Chrome al español es penoso, pero al ingles es bastante aceptable.
Publicado: 22 May 2015 10:37
por Whisper
Lo que decia..un toston -507 Yo quiero un sistema mas cerrado!!: Plug and PLAY
Aparte del manual exiten por ahi, zip compromidos con algunos montajes de juegos y mas juegos, que se vuelcan en la tarjeta SD pero muchos no funcionan: deben estar mal configurados los scripts.
Por cierto, GroovyDrifter has probado el ultimo firm (R022D) para la tarjeta? ¿Qué tal va?
Publicado: 22 May 2015 10:39
por Whisper
Yo te la recomiendo si te gusta mucho cacherrear (y tienes MUCHO tiempo libre...)
Publicado: 22 May 2015 11:06
por groovydrifter
Pues lo tengo puesto desde el principio asi que si es mejor o peor no se decirlo... una de las colecciones que me bajé fue la de Dabone asi que el upgrade era imprescindible. Otra cosa buena: con el firmware vienen las fuentes así que para el cacharreo te puedes currar un software al gusto. Si supiera corregiría la manera de paginar... un tanto cutre.
¿Has mirado no sea que estés probando una colección NTSC en un vic-20 PAL? A ver si por eso te fallan tantos...
Al fin y al cabo lanzar un juego en cartucho no tiene mucho misterio: cargar el fichero a RAM, hacerla de solo lectura y reiniciar el vic-20... y si quieres añadir un juego no hay que pagarle 2$ a alguien para que lo añada...
Publicado: 23 May 2015 11:51
por Whisper
GroovyDrifter escribió:Pues lo tengo puesto desde el principio asi que si es mejor o peor no se decirlo... una de las colecciones que me bajé fue la de Dabone asi que el upgrade era imprescindible. Otra cosa buena: con el firmware vienen las fuentes así que para el cacharreo te puedes currar un software al gusto. Si supiera corregiría la manera de paginar... un tanto cutre.
Respecto a lo de la actualizacion debes tener cuidado. Como muy bien sabes este cartucho tiene 2 firm: el del SDIEC y el verdadero de la tarjeta Final Expansion 3. Yo actualice el del SDIEC y las luces/leds dejaron de funcionar correctamente. No se como consegui hacer un downgrade. No he actualizado el otro firm, el del cartucho: viene con la version r21 y tengo la 22d, como te he comentado con anterior. No me atrevo a actualizar por la experiencia con el otro firm. Por eso, preguntaba, por si habias actualizado y si habias tenido problemas...
Respecto a lo del PAL/NTSC que te refieres, he probado con varias colecciones: "dabone_collection" (la que tu decias, la tengo), fe3_first_sd_card, FE3-Cart_Collection.. como ves tengo un porron y a todas les pasa algo similar: si no mal recuerdo son mas los juegos que fallan a los que funcionan. Ademas, si no mal recuerdo los tres pack son casi clonicos...con los mismos juegos
