Hilo de actualizaciones y novedades para MiST, MiSTica y SiDi
jorsus
Agradecido : 101 veces
Re: Hilo de actualizaciones y novedades para MiST, MiSTica y SiDi
Mensajepor jorsus » 07 Oct 2020 00:16
Amiga RTG
minimig_mist_rtg_201006.rbf
- Significant performance increase of the Fast RAM cache
- Master clock is switched between PAL (28.375 MHz) and NTSC (28.6363 MHz)
- The old video filters for chipset video are re-enabled
https://github.com/mist-devel/mist-bina ... inimig-aga
Agradecido : 2340 veces
Agradecimiento recibido: 2141 veces
Nuevo Firmware MiSTiSiDi
Mensajepor ron » 07 Oct 2020 18:57
firmware_201006
- Add clock_freq setting to override Minimig master clock
- Fix detection of SD card capacity for blocksize > 512
- Support DB9 joystick remap
- Fix joystick test for DB9
https://github.com/mist-devel/mist-bina ... 201006.upg
jorsus
Mensajepor jorsus » 11 Oct 2020 15:28
firmware_201011
- Fix the clock_freq setting
- Add a mouse_speed setting to scale the mouse movement by percentage
https://github.com/mist-devel/mist-bina ... r/firmware
jorsus
Mensajepor jorsus » 17 Oct 2020 23:13
minimig_mist_rtg_201017.rbf
- Fix the RAM selector (applied only at reset)
- Fix Chip RAM mirrors (Kickstart 1.2 works again)
- Slight Fast RAM cache improvement
- TG68K update - all instructions pass the tester
jorsus
Mensajepor jorsus » 20 Nov 2020 15:41
amstrad_201120_r005.8.16.8.5c
- reset on simple_gatearray_interrupt
- => moustache stress test stabilized
https://github.com/mist-devel/mist-bina ... es/amstrad
jorsus
Mensajepor jorsus » 21 Nov 2020 17:42
Atari 2600
a2600_201121
- Fix 2k cart mirroring
- Fix 8k cart default bank
- TIA: fix center signal (Bird and Beans)
https://github.com/mist-devel/mist-bina ... ores/a2600
Mensajepor ron » 23 Nov 2020 07:23
Minimig-AGA: new release
minimig_mist_rtg_201122.rbf
https://github.com/mist-devel/mist-bina ... dde47e6834
Fix border blank (by AMR)
Add +4MB Fast RAM (+2MB if Slow RAM is enabled) (by AMR)
Enable the cache for Turbo Chip RAM
32 bit access to normal Chip RAM in AGA
Slow RAM is always Turbo in AGA
Gayle IDE irq flag fix
Swap left&right audio channels
Mensajepor ron » 23 Nov 2020 09:04
ron escribió:Minimig-AGA: new release
Mensajepor ron » 23 Nov 2020 18:21
Nuevo update de Atari ST del core MiSTery
https://github.com/mist-devel/mist-bina ... 201122.rbf
Soporte the red añadido.
jorsus
Mensajepor jorsus » 23 Nov 2020 19:27
Firmware_201122
- IDE handling cleanup
- Send Ethernet config periodically to the FPGA
- Add 0b95:772B noname USB Ethernet adapter
- Composite blending setting for MiST2
Mensajepor ron » 23 Nov 2020 19:52
jorsus escribió:Firmware_201122
Os recuerdo que este mismo firmware es el que lleva la SiDi, con que podéis actualizarla sin problema.
jorsus
Mensajepor jorsus » 23 Nov 2020 20:11
Ron. Estaría increíble una Retrocripta sobre como configurar Ethernet en la Mistica y que adaptador USB es compatible.
Creo que no hay nada hecho sobre ese tema en el idioma de Cervantes. Lo poco que encuentro está en guiri.
jorsus
Mensajepor jorsus » 26 Nov 2020 17:38
Atari ST
MiSTery-201126.rbf
- Fix some reset issues (shifter desync, extra RAM)
- Simulate up and down keypresses with the mouse wheel
https://github.com/mist-devel/mist-bina ... es/mistery
Mensajepor ron » 26 Nov 2020 18:08
Finalmente nuevo FIRM para MiST
firmware_201126.upg
Mensajepor ron » 02 Dic 2020 07:47
TI99/4A: add an FDC (PHP1240 compatible)
https://github.com/mist-devel/mist-bina ... 201201.rbf
Mensajepor ron » 13 Dic 2020 01:08
Mensajepor ron » 20 Dic 2020 17:48
Acaban de actualizar el FIRM de MiSTiSiDi hace media hora
https://github.com/mist-devel/mist-bina ... 201220.upg
