Dragon 32, 64 y CoCo en tu FPGA a través del Core Minimig
Agradecido : 1752 veces
Mensajepor ron » 01 Nov 2019 21:51
Con el emulador DREaM, en versión 1.0.2 y un Amiga 1200 es un auténtico lujo.
En este caso el core Minimig y la MiSTica como FPGA principal, haremos prueba en MiSTer.
A partir de las 22:30, hora marciana,
Evento en Twitch: https://www.twitch.tv/events/EFw-ZbVfSUyusD_sN4xbkA
RetroCrypta en Twitch: https://www.twitch.tv/retrocrypta
Agradecido : 2668 veces
Agradecimiento recibido: 1143 veces
Re: Dragon 32, 64 y CoCo en tu FPGA a través del Core Minimig
Mensajepor minter » 01 Nov 2019 22:09
Pillesme en la calle pillandome una fartucada!
Ye que gustame gysarapear a lot!!!
Mensajepor ron » 02 Nov 2019 00:30
Alucinante. Funciona todo, todos los juegos son jugables y suenan !!!
Solo se dispone de carga de ficheros .CAS, pero al emular Dragon 32, Dragon 64 y Tandy Coco, triiiiiiple oiga !
Y con un A1200 Stock supuestamente va al 100%.
dream102.zip
(169.57 KiB) Descargado 9 veces
Sean Siford, (C) 1995-1997
System Requirements
The emulator requires a minimum of a 68020 microprocessor
(sorry 68000 and 68010 owners), and V1.3 or better of the operating
system.
A minimum of 450K of free ram (preferably fast ram, though about 75K needs
to be chip) should be available on running the emulator.
The emulator has been tested on versions 1.3 and 2.04 and 3.0, but may well
work under 1.2 also. Not having access to a machine running V3.1 of the
operating system, I am unable to say whether the emulator runs under it, but
there should be no reason why it should not.
The emulator has very few additional requirements:
The emulator uses Reqtools.library, which needs to be present in the Libs:
directory of your boot device in order for it to run. The versions for
V1.3 and V2.0 and above can be found in the Reqtools directory found in the
archive.
Also, a copy of the ROMS of the machines that you wish to emulate need to
be accessible to the emulator on startup.
The emulator expects the images for each ROM to be named as follows:
Dragon 32 - dragon32.rom
Tandy Coco - Tandy.ROM
Dragon 64 - dragon64_1.ROM (32k compatible)
dragon64_2.ROM (64K Basic ROM)
The emulator expects these images to be found on the volume DRAGON:.
The ROM image is not supplied with the emulator, for legal reasons - if
you find it with the archive, someone else has included it with the
archive - not me..
So, you will need to create an assign called DRAGON: where the ROM files
can be found:
E.g. If the ROM file could be found in Work:Emulators/DREaM/
assign DRAGON: Work:Emulators/DREaM/
alberchi
Agradecido : 19 veces
Mensajepor alberchi » 02 Nov 2019 09:15
En mist lo has probado también ?
Mensajepor ron » 02 Nov 2019 11:41
Si, está probado en MiST / MiSTica como plataforma principal, además con el último core minimig.
Ídem de lienzo en MiSTer. Con lo que en las FPGA es totalmente operativo y funcional, ya que es un emulador para Amiga.
Con máquina física un A1200 es más que suficiente y con la configuración de stock.
alberchi
Mensajepor alberchi » 02 Nov 2019 12:43
Genial entonces. Luego lo probaré. Ya solo nos queda el ORIC !!
Mensajepor ron » 02 Nov 2019 13:08
alberchi escribió:Genial entonces. Luego lo probaré. Ya solo nos queda el ORIC !!
ORIC ya hay core tanto en MiST / MiSTica como en MiSTer.
Lo que queda pendiente es la carga por audio, he hecho bastantes intentos pero de momento todo muy discreto.: viewtopic.php?f=86&t=200035026
En todo caso tienes el AmORIC para Amiga, que a la postre hace lo mismo que el DREaM pero con Oric -507 -grin -rofl
